light on the dash :(
for the last month ive bin having some trouble
sometimes when i start the car(in cold or warm conditions) this light comes on (c pic below)
then the engine will just rev agressively for abit then just cut out :(
somtimes does it when im drivin aswell like when i stop for a roundabout the light will come on and the engine will just cut out... :( mostly does it when i start
any ideas to what the problem might be???
all help appreciated
car is a 2002 1.2 16v dynaminque
1.2 16v engine suffers from a lot of similar problems
a) Spark Plugs
b) Coil Pack - very common
c) TDC sensor
d) Coolant Sensor
e) Throttle Body- costly
f) Wiring loom on back of engine being cut away by metal work
g) Throttle pedal
h) Oxygen sensor - 2 under car pre/post cat
Those are the items to investigate
Sounds like you may have a fault code stored, get the code read by a local garage.
This will narrow down where your problem lies.
If you are local to Coventry or Surrey i can do this for you.
Unless its under warrenty dont bother !!! They will rip you off left right and centre
Cannock is about 25/30 mins away up the M6 from me. You can gladly pop over to mine and i can whack it on the computer for you.
M6 Junct 3 im at
Yup its about £65+VAT diagnostics charge just to "have a look" at the car
