Lightened and Balanced Flywheel
  C63 AMG, F430 & 172
would this be a mod you recommend whilst the engine and box are out?]
going for a nice spec engine (200-210 ish)
worht it?
how much do you reckon it will cost?
worht it?
Nope.
Nice spec is 240hp plus though best nice spec is bottom end being properly done.
Mods I'd do well cams and headwork ballanced bottom end ligthened pistons.
refurb the gearbox might as well
new clutch
new mounts
clean all the bits
New camshaft seals infact all new enigne seals which may leak.
Full service cambelt chnaged
Remove air con maybe
New water pump and radiator
new suspension all round damper OE Renault ones.
4-2-1 182 or similar manifold
new battery
clean and piant all the car where needed
does the 172 have this as standard?
Nope.
  C63 AMG, F430 & 172
Nope.
new clutch
new mounts
clean all the bits
Remove air con maybe may do this
new battery
Nope.
the bolds im getting done, how hard is it to remove the air con?
new alternater and braket? etc?
new battery
new alternater and braket? etc?[/QUOTE]
Use the Cup setup remove the air con compressor and the condenor also to do the job right I'd change the whole heather matric setup for a one air con as I like stuff done right then again there no need.
Deffo do the battery its only cheap if you cannot prove the old ones ages
Just check the rad for damge might be fine since the condensor takes the stone chips and removing it means the extra heat from the more powerful engine can be cooled.
O yep I'd personaly do a oil temp/pressure gauges
  C63 AMG, F430 & 172
removing the air con should save a good 40kg's?
i was thinking of doing a battery re location to the boot, but will change it either way
