lights dont work?
  RenaultSport clio182 B/G
hiya, just a quick question, my xeons do not appear to be working however both my fogs and sidelights are fine. Do you have any idea wot the problem may be??? I have checked all of the fuses and all seems to be ok. What i fort was weird was that when i switched on the lights it did not show the dipped lights pic on the dash. I am stuck, any ideas?????? Thanx
V
v11ous
it could be relays or a swith problem if your saying the headlight image doesnt appear on the car or it could be the ballist
  Golf R soon...
Had this same problem with my 182, only the xenons were not working!
Putting new fuses in and the blew straight off!
Took it to Renault.
Turns out the drivers side entire light cluster had to be replaced because it was letting water in and blowing the fuses!
Covered under warranty, thank god!
Get it into a garage if its still under warranty!
it turned out to be a loose relay under the n/s footwell. thanks for your help. thats a weight off my mind. :)
