Lights!!!
Car  172 cup
Went to put lights on last night and all my bulbs seemed to blow.
Do I just need to replace them all or is there something more wrong?
I was thinking it would be the fuse, where is this?? Is it in the side of the dash?? Do I just replace it
ph2 passenger side of the dash, ph1, not sure
edit - expanding on that, if you open the passenger side door and look where the dash meets the door car there is a flap of plastic that pulls off, they are there
You may not need to go there as you may have a spare one there (you just need to remove the old one and put the other one in) if they are the same rating it's all cool.
you might already have a spare fuse Laura,
When you pull the plastic flap thing out on mine it has some fuses stuck to it and some little plastic tweezers to help you pull the old ones out. Worth a check before going and buying some more !
Just make sure you use the same rated fuse (matching numbers)
Edit: Doh cat ! ^
Ah even better, think Ill check straight away after work as I need to go somewhere tonight and dont fancy driving in the dark
