Ph1 172 & Clio DCi
Right basicly I have a Ph1 172 and a 182 full fat and the are both suffering from the most annoying problem ever!- They dont start lol
Heres some background info
172- I bought this off ebay as a non runner. The last owner took it to renault and they can't figure out whats wrong with it. He then changed the ECU, chip and the little circut board thing thats part of the immobliser. It still didn't start. Then i Brought it. The fuel Pump primes and runs when cranking. The Injectors have a 12v feed and are firing. The coil however has no 12v power feed and therefore is not firing the sparkplugs. It has had new Plugs, Leads and a coil by the last owner.
182- Again I bought this as a non runner. The engine had blown up. The last owner took the old engine out but couldn't put it back in. so after sitting for 8months I brought it. I have installed an 8000mile old engine and it will not start. It has exsactly the same problem as the 172. The fuel Pump primes and runs when cranking. The Injectors have a 12v feed and are firing. The coil however has no 12v power feed and therefore is not firing the sparkplugs.
This problem is really doing my brain in! No one i talk to has ever heard of this problem, yet i have 2 cars doing exsactly the same thing!
Has anyone got any ideas?
Also is there a relay that has to switch to turn the coil power on? if so does anyone know where it is and what triggers it.
Any help will be greatly appershated.
Mike
Mike
