Little Problem on my 172, please help.
I found my 172 is a bit non-stable when idle, I don't know if i should say idle because the rev is stable. But just the car has tiny slightly shaking when stopped. I can feel it from my seat.
Is that caused by sparkplug? Misfire? But acceleration is fine. I had cleaning the throttle and the inlet manifold. Plus I do use those injector cleaner every 5,000km.
I just don't like the slightly little shaking. Does anyone has similar problem? Or it is a common problem. I want my Clio in perfect condition.
thanks!
  172 ph1 ASBO SLAYER
could be a missfire causing the engine to move about, or more likley a worn engine mount causing a rythmic pulse/vibration felt thru the seat
Which one can mostly cause this problem. I had changed the top driver side one during warrenty period. Will the K-Tec one for lower solve the problem? Are they good and easy to fit?
  M4 LCI, X1, ZX10R
That seems like the general thing with the 172/182's none of the one's have been have had a smooth idle.
If you ask Renault they'll say that they all do that.
It's what happens when you have a high revving engine, i guess
Ali
  V6, Trackhawk, GTS
My engine mounts went a couple of months ago...Didn't have time to uprate the bushes, but the k-tec one's will help i'd imagine. Easy to fit...well, a garage ill take anything from 2-4hrs!
