howsit gents, noticing a problem when starting the car while its still warm, at least 70 to 80 deg on the coolant temp, itll start fine then the revs will drop very low after the initial starting blip before it climbs to around 750 again, while reading live data I noticed that with the engine off, its still showing 250 RPM, on other cars I've used the unit on ( cheap bluetooth 327 unit) all the values are as to be expected... just wondering if its one of those french things or could the tdc sensor be on its way out...
anyone had a similar problem?
