Longer wheels nuts ?
Renault run bolts as a standard fitment. You requiring longer bolts me thinks. Unless your running spacers thats the only reason i'd think you need longer bolts.
I am running rear camber 1' deg and the wheel bolt do not need to be changed.
I am gonna be running 6 degree camber I was thinking will 35mm do the job or will I have 2 go longer standard bolt size is 26mm
Why is it that stupid kids these days are so determined to turn their cars into death traps?
The sooner this country gets a proper TUV style system the better, even though that means an end to all my own weird and wonderful projects too sadly!
No, camber doesn't effect wheel bolt length.
Effects tyre wear and grip though, badly in both cases for -6
It looks like the rear beam has been knackered in a crash.
Will also tuck the top of your wheels in quite a lot making it look like its narrow, which is where you are getting the bolt idea from as to complete "the look" you'll want to run about 30mm spacers on there too to push your wheels right out, thus fully giving it that "im a clueless emo c*nt" look
I am running 7.5 j lenso 16 inch and I am thinking of running 4 degree camber at c what that looks like
