look at this,what is it?
Car  clio 1.8 16v
are these any good,£39.99???
yea solder it onto your ecu and it wil raise your rev limiter and a few more bhips will be available
worth buying then? ive already got quiet quick acceleration and a high limit as ive got piper cams,will it still make a difference?
Being as you don't have a 20 bottom end don't bother. It will limite the rpm since the 2.0 won't go as high and will overful.
Plus this doens't say what its mapped for ie cams intake stuff.
IMO in order of preference top being best I'd do either
Get a 2.0 bottom end then get it properly mapped. (only one I'd do)
Get a 2.0 bottome nd and get one of these from gunnner gibson on williams clio he will sort you a better suited one won't be perfect though but for price better than not having a map by miles.
Get your ECU mapped ro least A/F checked see if it is mapped.
Quick acceleration mens nothing you need to check on the A/F ratios etc.
How high is your limiter although it doens't mean much since the rev counters not that accurate somtimes.
thats not that high for a valver.
I didnt realise you had a 1.8, no point getting it then
