looking into getting a 1*2, common faults to watch out for?
banderson
  05' BG 182FF
hey all, got a mk1 clio valver at the minute but looking into getting a clio sport as mine is getting tired now (got my eye on the 182 more tho)
is there much to watch out for on them in case i go look at a few?
cheers
  Laguna sport tourer
main thing would be gearbox i suppose, if you go for a 182 also check condition of the exhaut as they fill up with water
banderson
  05' BG 182FF
so theres not much else thats a common problem? i am mechanically minded so looking around it wont be an issue...just be nice for the heads up on where to look first :D
and thanks for that 182cup :)
check the mileage as you should do a cambelt change around 60000ish, so ask if it had that done if not your looking at about £500 in the future.
  Laguna sport tourer
1.clutches can sometimes be heavy cure is to replace 2. tdc sensor may need replacing with a new type one with longer wires. 3. dephaser pulley may need replacing. thats about all i've had with mine. just realised you live in thetford i live only 15 minutes away. p.s are you gonna be selling the valver
Greeny.
  440i + 182
Hey, im going to thetford to pickup my car from JMS tyres tomorrow :) If you end up getting one make sure to come along to some local meets mate :)
As above though really, gearbox can go, mine went before I got mine but touch wood on the whole its been fine for 3 years of fairly hard driving, just had to replace the following but my car is on 89k now! Plugs, HT leads, coilpack & injectors, all in all though its been a good car. Make sure the belts have been done as its due 5 years / 72k which costs around £500 to do which is the last thing you want after forking out for the car! Try and find out who carried it out when it was done as there are so many threads on here of the timing being out due to the wrong tools being used.
  tiTTy & SV650
182 exhausts hold water check for corrosion,
look for oil around the cam cover it leaks VIA the bolts,
182 rear shocks fail quite often look for signs of oil on the shocks.
Engine and gearbox mounts can be iffy and cause a banging on hard acceleration,
check boot floor for damage as they crease easily,
check joins where rear quarter panels meet the tailgate frame,
watch for vague / loose steering if noticed look at track rods and rod ends and rear shocks
  Focus RS mk1
check the heaters work, resistor pack common fault! leaking headlight washers, nakered washer motors, knocking engine mounts, cruchging gears at high revs, squeeking release bearing.
banderson
  05' BG 182FF
thanks everyone :D if (or when) i do get one i will be coming along to some meets and that for definately! lol
alot of them faults and that are fairly easy fixes for me if i do find any as i am a mechanic for KIA/Ford garage in thetford! just would rather not be doing the jobs as i work on other peoples cars all week long :p
and 182cup i may possibly be selling the valver but i didnt really want to if i could help it as i love the 'rawness' of it. been my baby for 4 years but needs a few bits doing now which i would like to fix as a 'project'
  Laguna sport tourer
cool :cool: if you do decided you are going to get one you can always have a go in mine for something to compare/benchmark if you like
