White Clio 1.2 @ 172
Ok,
I'll try and keep a long story short. I managed to damage the inside wiring harness for my 1.2 Clio 1998. It's sat off the road for a while
, I have been contenplating the 172 Conversion for a very long time but money is fairly tight and I have some other priorities at the moment.
With that in mind I have a damaged loom and a car which will no longer crank/function so I intend to pop to my local scrappy to pick up a new interior loom. Now I remeber reading during the 172 conversion thread's that the UCH and ECU have to match from the same car I'm hoping this is not the case as I don't want to have to replace both looms and the ECU.
However I would like to switch to the Ph2 dashboard with the 1.2 16v Cluster. So I was wondering if I could harvest the internal loom from a 1.2 16v and dash/cluster/stalks and pair it with the engine loom (plug&play?) from my 1.2 8V (1998) as I really don't fancy sticking with my ph1 dash or with cutting up a new ph1 loom to rewire the cluster.
Depending on the answer's to the above questions I'm wondering if I would need to have the plip recoded?
Thanks in advance
Dean
Thanks in advance
Dean
