Loose interior Door trim
ex-Chinese Dave
  172 Cup
You can see from the video that this piece of trim is loose. It’s had three new clips fitted to it and they are all in place, but the bottom part where it joins with the door card is a bit loose. I’ve just fitted a new piece of trim so I had the whole door card off again. Everything has gone back correctly and this piece of trim was loose before I took the door card off first time. Has anyone got a solution for it because there are no clips to hold the bottom part in place and I can only think of using some form of sealant or s
ome double sided sticky foam. Any ideas are welcome.
ex-Chinese Dave
  172 Cup
I found a metal clip that had come off (see my project thread) so it needs to be fitted to the trim that goes up the side of the door. I've checked the passenger side and the trim fits with a gap (that's Renault build quality back in the day, no doubt) but it is secure. I've also looked at some good cars that were sold on Collecting Cars and they look the same as mine does. It's just the way they were made, I guess.
  Clio 2 ph 2 1.4 16v
Reno does have some weird gaps when it comes to plastic stuff inside the car .
  Clio 2 ph 2 1.4 16v
I think they are called 'French Friday afternoon' gaps :ROFLMAO:
Funny that you mentioned, i work as a tech for bentley and when im doing a pdi on a brand new car and something is not put right on it we call it (friday before pub job) i had one where the car had no rear bumper , because is was involved in a crash in the factory and they put the new bumper inside the car ...
