loosing water
  clio 182
after driving my clio 182 about 500miles the water drops about 1" is there anything i should look out 4 is there any common problems with them
DrR
  VW Golf GTD
Does it then stay at that level or keep loosing more water if you keep driving?
  Clio MK 4
the pipe around the bottom of the radiator has a tendancy to leak.
what he said. Get it checked out and make sure you dont run to low. May need a new radiator. Mine was leaking so much i had to fill a bottle every 2 days! Yet couldnt see any leaks on the floor! Had radiator replaced and fixed. cost 100 quid.
