Low Mileage Evo 8MR
I know I'd have an 80 mile one than a 50k one.
Why would you want a used one when it's as new ?
Do people never think a cars not being used for a reason? And cars hate sitting still not doing anything..
Or it could just be clocked.
Each to their own, because condition would normally be decent if only covered low mileage so irrelavent really. Low mileage is vital IMO, hence newer cars ftw.
Whys everyone going on about servicing when it's only done 80 miles ffs.
It has just been serviced as it would need new oils, pugs and belts anyway.
It's been serviced once in 7 years...
evos need servicing every 6 months!
Any mechanic will tell you cars hate sitting still for ages.
Cars get very tight after sitting some time, and parts (perticuarly rubber items) will degrade in that time. Massive waste just sat there but a bit of cash to renew some bits and it should loosen up.
I'd rather one that was used more, No doubt most rubbers have perished on that one.
LOL at people saying they'd want a higher mileage one.
You could always put miles on it if that's what you want.
Within reason
Obviously, 20k is better than 50k
But in this case im not so sure.
How would the tyres be having been sat in the same position for so long?
people will be saying it needs a cambelt change because its 5 years old :rolleyes:
Full r****d. You just went there.
The reason it states X mileage or X years is because they deem that within X years the belt will be deteriorated. It's not a case of "Oh it's been used for 5 years now so it's probably worn out." it's to do with the longevity of the part itself. Even more so if it's been sat as it will become brittle and dried out.
You absolute dunce!
Ya ask for peoples advice then tell them they are wrong.
Evo's have a belt changed between 3 (320+spec) and 6 (240-320 spec) years at the cost of around £200, yet in Mr Dunce's (jordi) case at the cost of £2,500 for a new engine.
You put some thing like a strip of rubber with a 5kg weight attached for 5 years and it will gain size or even snap. This is what will happen with your belt you twallop.
An rubbers perrish, sat dry for 5 years or not some thing will give way.
I am not the brightest person in the world, yet your making me look like a freeking Wizzard!
They quote 5 years or 72k miles. If you do the 72k at the 5 year mark, that peice of rubber has not only lasted 5 years, but also been driven for 72k miles. So youre telling me its just as worn as one with 00080 miles on, I dont think so. It detioriates i get that, but not that much, no chance.
Rubber degrades you muppet if that was on the orginal belt sat in the same position for x amount of years the chances of it snapping on your first start up are huge.
Jordi the manufacturers recommend these figures for a reason.
Well put it this way, my sisters ibiza was due at 60k - never got changed till 71k.
Fantastic, glad she got those few extra miles out of it. The point is, if the cambelt DID go (there's a possibility, I know, mental isn't it?) after 60k miles, then she'd have to fork out for the repairs which would far exceed the cost of having the cambelt changed.
Of course some cars will last longer, but why risk it? The manufacturer won't have plucked a random number out of thin air 'I know, lets just say 5yrs or 72k miles? I mean people like Jordi will obviously know we've drastically underestimated, but the rest will follow like the sheep they are!'
No. There's a reason, and that reason is rubber perishes. Same for tyres, just because they've got 7mm of tread on them, doesn't mean they should be used if they're outside of their sell by date!
Right experiment time or a bet for Jordi.
I have a spare wheel from one of my mates old cars, it had a brand new tyre on it and it was never used on the road.
It's been currently sat at the top of my garden wrapped in thick plastic film used as a bird bath, I would say its been there for round about 6 or 7 years.
Now I do not know what pressure its been under, now it says on the side of the tyre that the max psi is 54psi.
Heres the bet, will it still be able to make 50psi? I am not showing you what it looks like but from your arguement that if it is stood for X amount of years and not done anything that it will still be fine to use. How much are you willing to bet?
Sure as hell I am making it a long air line when it goes bang, even if it does only reach 35psi.
Video's please.
