just had the passenger seat out to take a closer look at how everything is setup as standard.... anyone think this idea would work....?
ok... remove the sliders etc... get a metal plate made up like shown below:
this would bolt to the 4 bolts that the original sliding mechanism bolted to...
then in this plate, there would be a series of holes drilled down each side, so the seat can be bolted down... but the series of holes means the seat can be moved forward and backward if needed. this would not bother me as i would be the only one driving....
would this solution be safe? and are there any companies that would manufacture this sort of thing for me?
cheers![]()
cheers![]()
that what I was saying no need for the cross members though.
however its not going to lower you much plus you want some thick metal to make those runners out of realy so not huge gains.
