low temp thermostat easy to fit
do it as quick as possible
while ur doing it flush out the whole rad/ cooling system
i got mine from reno but u can get them from most good spare stores. andy spared do em ect
the stat is a 82 oc opening one and a switch is off a R5 turbo
both easy jobs to do
yeah buit they charge more for the parts bb do em too but if u shop around u can get them much cheaper
think i got my stat for £3 and switch for £7
i got them from my local car spares they will have two stats listed for our cars one being 89 oc hot running and 82 oc colder running one
fan switch is just a reno 5 turbo low temp fan switch
wongy
in a large car spares place the only stats i could get were smaller in overall diameter, is it definitly a 5 turbo stat? 82? in the end i replaced mine with a brand new OE williams one but it still runs hot all the time, and because i replaced the rad fanm switch the fan is coming on all the time, i tried a 82 stat that was a few mm smaller and it didt sit tight and the water got round the edge and mangled the gasket.
Ive got a low temp fan switch but was advised against getting the low temp thermostat, as I was told the ecu will think the engine has not warmed up properly so will keep the mixture slightly rich.
Does anyone have any problems with the low temp thermostat?
mr feltham where u been hiding
anyways the stats are available from reno if u have problems fiding one. reno themselves make this stat and are known to use them but im not sure where, maybe it was used in countries that were hotter than france, i dont know
mine runs at 1/4 on temp reading and only really heats up when in trafffice where the fan will cut in early, works a treat for me and car seems to like it too. cooler running valver can only be a good thing
wongy
  Clio Williams 1, 182,197
Mr Wong
What is the date ??
Mmmmmmmmmmmmm new registration yeaterday !! Lots of people wanting to collect there new cars !! Foooooooking busy mate !!
oh yeah forgot mate
ill be down to nhave a chat with u if ur not too busy this week sometime need new clock bulbs damn things are reno only
wongy
