lower than H&R
Gaz_
  Extreme mode
is there any rear suspension set ups that lower more at the rear than the h&r jobs?
just wish mine sat another 5mm or so lower, as its wound down to the max already
it would be nice to maybe just have some replacement springs and/or platforms, but keep the dampers
anybody any thoughts etc?!!!
Gaz_
  Extreme mode
hhmmm, wonder if i can keep the h&r dampers and just change the spring set up?
One thing i toyed with was getting an engineering company to modify the rear adjustible platform the spring sits on. Should be enough to drop it that little extra you want without changing the ride.
Or some Fk ones, if its just a case of dropping it a few MM im sure a different set of platforms the original ones modded or a set fabricated will be enough.
  Audi A6 (S3 on order)
The Leda setup will go lower than all those options with the height platform in place as they use a small race coil. Will probably balls the handling up though.
