lowering help please
Car  Mk2 P1 Clio
hi, ive got a mk2 p1 - just got it
is the suspension the same as 106s (my old car)
springs at the front and torsion bar at the rear? thanks, tom
options are 60mm springs, coilovers or Air and that's also in order of cost
and also cud someone post a pic of a clio dropped 60mm just so i can get an idea of how low it wud be.. cheers :)
You could also get 60mm springs and shocks. That way you'll have dampers that are designed to work with the shorter springs.
I bought some KTR'S coilover kit. You can go 60mil on them and for the money they are a cracking piece of kit with lots of members on here recommending them.
cheers for that mate, thats quite nicely lowered, think ill go for 60mm. would it look alot higher if i had 15s? cheers
It would look lower, and better, on 15's. As its a non-sport you may as well go for a Rokkor coilover kit
