As for warranty it depends on the dealer, some are funny about mods others dont care. Best to give them a call and ask them if they would have any issues with warranty cover if you were to lower the car.
i thought the warrenty was with Renault UK, not the local dealer
Mine is lowered 60mm and basically if i get a prob, then they have to prove it is the springs/dampers.. The only thing they dont cover for breaking etc is the suspension, which should be covered by the company supplying the new lower ones....
They can only refuse warenty work if they can prove the modification is responsible and most dealers cannot or dont want the publicity with refusing claims. Mine went in for work when it had coilovers with no issues.
Springs alone wont get you down 60mm though 40 is about the best I think.
Best get mathcing springs and dampers or coilovers though all the way.
you can probably get just springs that drop 60mm, but this WILL f*ck your dampers, shouldnt really drop more than 30mm on standard dampers. Its best not to lower on just springs anyway as this puts increased stress on the dampers.
