lowering questian again
  GONE!!Yozza'd BG 182
do you need camber bolts when lowering on eibach sportlines? just been told i will need £150 for springs, £100 fitting £20-30 camber bolts and then alignment on top of that so about £300 all in, that price was off a tuning specialist. i am obviously going to fit them myself because it is not rocket science and get alignment done at a smaller garage, but DO i really need camber bolts?
  182 FF
You dont have to put them in and sportlines dont lower the car that much anyway, but you may find some uneven tyre wear and the car may tramline on bad roads.
  Clio 172 Ph2
you don't need camber bolts after eibach sportline.
this springs don't lower that much, standard bolts will be just fine.
btw i'm running eibach sportline by about 1 year with OEM bolts and no problem at all.
