lowering question..
  • Thread starter Thread starter JACKO CUP 172!
  • Start date Start date
J
JACKO CUP 172!
after crimbo has gone i am thinking of lowering my cup:D
does this mean i will have to get the camber sorted. or have i heard wrong??:S
jacko
I would not bother - youll need the tracking adjusted but if only using springs I would not worry about the camber - Itll be more aggresive than standard as when you lower you get a more negative camber but it shouldnt be too bad.
id find out what peoples tyre wear is like with the lowering.. my old astra used to go through a set of front tyres in 4k on the inner edge.. get boring having to spend £150+ on new tyres just because you can't be ar5ed to set the camber..
if peoples tyres are wearing ok dont worry about it..
yeah i know wot ya saying.i dropped my escort 40mm and i used to go through tyres big time but just put it down to the tyres being 100% nylon..
mine are fine (wear even etc) i've got correcting bolts on mine, but its probably lower than 40mm lol
