lowering springs gone rong, FTL,
Car  clio 172
:dapprove:HI everyone ok i have just fitted lowering springs .apex can some one please tell me what i have done rong.The backs are fine but the fronts are the problem.]
right when i turn the sterring wheel left bong bang .when i turn the sterring whell right bong bong .basicly the springs dont seem to be held tight enuff there spinging when i turn the wheel.and where the springs are sapost to sit they move around.could i have done something rong..can someone please post a guid or a diagram of how the shock sping and part go in order.and eny ideas would be great.meny
meny thanks avit ,louis
CS, recently, ftl.
They fit the reverse of the way you stripped them down?
i didnt strip them down my friend did as he has fitted springs to his car as i did the backs he did the fronts.i have since took the fronts of but dont no wich parts go were.
take them to a garage to get them done
As by looks of things you don't know what your doing, and neither does your mate either IMO
At least that way they will get fitted properly and won't trash your cars suspension any further (apex ftw) LOL
Not trying to be nasty btw
no that is what im going to do i should have took it garage in the first place tbh.but would rely like to see a diagram of what it should look like if enybody on here has the time to show me as i have spent about 2 hours looking online
to be fair its probably best to get it done properly as its not ideal if they end up coming out whilst driving along.
thing is i dont no if they are missing parts now or whats happend.why is there no pictures of everythink that gose together to fit them online ,.
there is a guide on here on how to do the full thing
Think you need to be a full member though
On iPod so don't know how to copy paste yet lol
But type this in to search
Guide - how to change/replace front worn suspension
That should bring it up for you
thanks guys yes they both worked.i think ino what was done rong.
staring from the top dose the rubber that sits on top of the shock bolt on to the shock or just sit on it ???/
If you mean this bit:
It bolts on yes, it should look like it does in the above photo.
Then when you push the shock through the hole in the chassis, the top mount also bolts on to the same thread.
just to let you guys all no car is sorted what was rong
1)got a firend to help on somethink i could do
2)let my friend do it
3)what was rong my friend he put the bearing part underneath the first rubber instead of inbetween the two rubber mounts
cheers and if enybody ever needs a diagram off how things should fit go to gether or work then just go to renault they will print you off a diagram FTW
