Lowering the valver?
  Sunshine Bus ph-quick
I fancy lowering the valver, but for some reason can only find the majority of places selling springs, not shock & spring kits.
Anyone any recommendations on brands?
Not looking for a huge drop, just 40-60mmish.
x
mossyv6
  Trophy,V6,5GT,AG200
Ktec stock -60mm Apex lowering springs and run fine with standard shocks.
  Mondeo TDCI 130
Yes you would be better with shocks really!, so you will end up with 4 uprated shockers and 2 springs, he rear is torsion bar! That will need adjusting to match.
I knew about the bar at the back :)
Someone mentioned I could use standard williams suspension or something? :/
  Mondeo TDCI 130
Quite possibly, to be honest, don't know a great deal about the early models, things you can swap etc!!
When i had my valver, i replaced the shockers with some bilstein aftermarket standard jobbies, improved it loads!
You could get new standard shock absorbers's, and some lowering springs at the front, just don't go to mad!! Depend's how much you have / want to spend!
You need to chnage loads do a search i wrote a topic saying hat you ned to chnage to have a williams setup and its a long lisdt and not cheap.
M
mini-valver
Standard dampers will last about 6 months with 60mm springs until the ride is shagged and they bottom out everywhere and feel unstabl cornering. 130k standard dampers will lasy significantly less than 6 months!
