Clio IV Trophy lowering springs
StingyCH
Car  Clio 172 PH2
Hi everyone! :) got a quick question about myClio RS EDC 220. I want to lower the car a bit, don't want to get coil overs again (got this solution on many cars in the past), I want, if possible, to keep myOEM shocks. Problem is..I can't find lowering springs for my car. They are available just for the 200, not the Trophy (which I know is already a couple of cm lower than the standard RS. Do you guys know if there's a brand that makes lowering springs for the Trophy?
There are no specific springs for a trophy so just get any you prefer.
For example I run cooksport springs on trophy dampers and it's perfect.
Don't expect much of a change though, rears won't look any different but it does drop the front so it sits better.
Done so much consideration on this myself. I've lowered every car I've had for 25 years 😂
I dont want the expense and discomfort of coilovers again, but I've decided to stick with oem trophy springs.
The cooksport etc do lower the front a bit more but only because they're a bit softer. I don't want to get any rubbing or faff on track. The 5 to 10mm front arch gap does get on my tits sometimes aesthetically though
It's so much nicer to drive on cooksports though!
Trophy springs are naff in my opinion, I'd rather have full cup and be able to hide in the arch when it rains 😂
I've lowered every car I've had, this is the first one I've not felt the need to. I find the trophy springs really good. Ph2 though so different shocks.
