lowest of the low!
Quote: Originally posted by merlincancan on 03 January 2004
i measured mine against a standard ride height clio with same wheels n tyres as mine n it was 130mm drop on the read but only 70mm on the front! i want it lower do you know if gaz do shocks for my model or do they make them to fit the vehicle?? mk1 ph3 1.2spi wit 52mm bolt holes!im havin a lot of trouble with finding someone to sort this for me! i dont know where to start looking!
Check the K-tec site, Im almost 100% sure that these coilovers will also fit a normal Clio.
da gaz/ktr shocks will only fit 16v n willy models-or so it says on the site n da only other ones only lower upto 80mm max! how much was urs lowered at the front "16 valver"?
Ive got GAZ coilovers on my 1.4RT
If you take out the bump stop its going much lower, but than youll get the problems I mentioned earlier.
