Lumpy idle an misfire at high rpm.
  Clio 16v
What does this mean in English?
  Clio 16v
This fault is not on the engine management side on my sapon mt2500 itit's under the abs system fault codes, after Alot of head scratches and a rollie, I checked the earth's an found one was a bit grubby so I cleaned it all up an now it runs better.
I also had the service, esp, abs, management lights on an after playing with the brake sensor an the earth I have only two problems the serv light is still on, and the esp light will flicker if I'm reving her high an it makes it bog down.
