Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
My 1999 clio brok doen last nite 1.2. the engine just cut out and i dnt know what really happand. ive been told it mite be the air compression can anyone tell me what the signs mite be? and how much it would cost? thanks. aiden.
yeh it cut out when i was driving. it didnt just cut out it slowed down then cut out. so i dnt know if tht was becuse it was loosing pressure. yeh it turns over and the battary is fine. as all electrics work. yeh when the starter motor goes its goin way to fast and its like winding. it just wont engage. thanks.
i do remember when it was happaning. when i put it in to 3rd gear and it sounded like the gears was grinding. so i took it out and put it back in and thats when i was losing the power.
Is the cambelt 100% ok? As you saying the engine is spinning over very quickly points at the cambelt broke - the engine will only be turning the bottom end - the cam and valve gear wont be moving as the belt would have snapped
If the cambelt is snapped it's not going to start??! You can't see the cambelt looking under the bonnet? it will be the aux belt you can see. Put money on it's broken.
