1.2 air con belt tensioner replacement. Help needed
  04 clio extreme 4
Can only find stuff about the sport models.
Standard d4f 720 1.2 with air con.
Just a question.
Do you just unbolt and rebolt the tensioner/idler pulley, or do you have to make sure the bolt/axle doesnt fall out the back of the bracket?
Can't find a vid of anyone doing it, manual says nothing about changing it, only setting it, and ive looked all over search engines and forums and can't find the answer.
That's all. Whats involved in replacing it?
  04 clio extreme 4
From memory you just loosen it the tension and tighten it again! Ages since I done one though
Thank you for the reply but it wasnt clear.
So you just take the old one off and put the new one on? No need to worry about keeping the spindle in place?
