management system
Car  Williams 2
hi all i got a quick qeustion
would it be possible to put some kind of button/switch in my car so i could change from economy mode to sports mode (more fuel and air intake etc) abit like how a turbo would change from low boost to high boost
cheers
I doubt it tbh, the best you could probably do is go for aftermarket management and adjust the settings with a laptop.
Or the cheaper option, go easy with your right foot :)
you can get an after market stand alone ecu which will allow you to programe 3 different maps and then switch between them using a switch in the dashboard
