Manual Tyre changer- bead breaker for DIY use?
chris blue
  clio rs 220 trophy
Constantly swapping tyres and paying £15 a pop each time at a local used tyre place
Reckon could be doing 8 a year or so
Anyone got experience of one of these car tyre changers/ bead breakers and are they as easy to use as the UTube vids? Saw one bloke get a tyre of in around 2 minutes
https://www.ebay.co.uk/itm/Tyre-Changer-Bead-Breaker-Tire-Car-ATV-Motorcycle-Manual-Hand-Machine-21/253809515916?_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20131017132637&meid=03f3f3697e5a4707b0b06cdc6e8652fa&pid=100033&rk=1&rkt=8&sd=232927879428&itm=253809515916&_trksid=p2045573.c100033.m2042
Didn't see him put one back on, but others have done it in several minutes
Expect its back breaking work?
Are they worth it- would save a few £'s that could be spent on the tyres
  Clio 182
I use a trolley jack and a ratchet strap to pop the beads.
Works a treat.
Obviously on track wheels or ones your not to fussed about.
  PH2 172
Works a treat.
I was amazed to watch a professional road side rescue bod this week.
Loose wheel on the deck, 1 inch Vee block about 5 inches long & a large sledge hammer to break the bead.
chris blue
  clio rs 220 trophy
Tyre levers and fairy liquid.
The pain is the balancing of them.
I'm hoping that where the original wheel has already been balanced with weights on the internal rim, then replacing the tyre should require new balancing
Tyres cant weigh that much differently?
  PH2 172
You have omitted the word NOT, and it will.
chris blue
  clio rs 220 trophy
I'm hoping that where the original wheel has already been balanced with weights on the internal rim, then replacing the tyre should NOT require new balancing
Quite right. Now inserted.
Does it matter on a track? Just a little shake, is it not? Feel free to advise.....
JamesBryan
It will need balancing, believe it or not tyres aren't perfectly round. Neither do they weigh the same all the way round either.
That's why you see the yellow and red dots marked on tyre sidewalls. Yellow dot is the lightest part of the tyre, red dot is the highest spot of radial run out (how out of round the tyre is basically).
If there's only a yellow dot you line this up with the valve on the rim. If there is both yellow and red dots, ignore the yellow and line up with the red.
Pauleds
  Merc Dueliner sport
(Insert hovis advert music)
When i were a lad, we only had one of those manual tyre changers.
They work all right in all fairness. Competition tyres with hard sidewalls were awkward though.
JamesBryan
One of the lads at Demon Tweeks struggled to get my Dunlop track tyres off with an all singing all dancing new machine.
Wouldn't like to try it with a manual jobbie.
Pauleds
  Merc Dueliner sport
Certain wheels were really awkward, Compemotive MO were the worst
  PH2 172
If you had ever ridden a motorcycle with an unbalanced front wheel, you wouldn't have asked that question.
Go fast enough and it will develop an uncontrollable tank slapper that will throw you off.
Unbalanced wheels will cause premature wear to wheel bearings, steering, & suspension components.
New tyres will definitly need balancing. All tyres are different and when they are spinning at x revolutions per minute you will feel the imperfections through the steering wheel.
R3k1355
I used to get part-worns off this old fella out in the country, he used a manual balancer.
Wasn't perfect but it was fairly close, better than no balancing at all.
