Map Sensor
Car  RB Clio 182
Just a quick one guys, my map sensor keeps almost popping out as the o rings are buggered!
Is it a new genuine, or are the ebay copies any good or are there any other recommended ones?
Cheers :)
new o rings??
Yea I think ill get some mate and fit them that's the cheapest option.
Its really easy to pop out too and ive had a couple of missfires under full boost and when ive had a quick look the sensor is almost hanging out.
Could this cause it to miss if its causing air leaks under boost?
It will be as a consequence of turboing it. You could tap two holes either side of it and use a bit of metal and 2 bolts to secure the sensor in place.
yes that's the proper way
or pikey way is to smear the o ring with 'no more nails' sealant type stuff and shove it back in,
I have 2 standards on motor vehicle maintenance
1, My clio and other people cars, I never bodge
2, My second car/shed duties is held together with no more nails, cable ties, duck tape and monumental levels of bodging.
