new o rings??
It will be as a consequence of turboing it. You could tap two holes either side of it and use a bit of metal and 2 bolts to secure the sensor in place.Yea I think ill get some mate and fit them that's the cheapest option.
Its really easy to pop out too and ive had a couple of missfires under full boost and when ive had a quick look the sensor is almost hanging out.
Could this cause it to miss if its causing air leaks under boost?
YesWill it be the result of more air flow etc?
The cheap ones are rubbish don't last 5 minutes.
I bought these o rings to replace the green one that had cuts in it.
http://www.ebay.co.uk/itm/321779167...49&var=510693651517&ssPageName=STRK:MEBIDX:IT
6.5MM ID X 2MM C/S
Although you should ask the person that done the turbo as I am sure he would have a solution.
Hi mate, was this the size required to replace the green o ring on the map sensor?The cheap ones are rubbish don't last 5 minutes.
http://www.ebay.co.uk/itm/321779167365?_trksid=p2060353.m2749.l2649&var=510693651517&ssPageName=STRK:MEBIDX:IT
6.5MM ID X 2MM C/S
YeahHi mate, was this the size required to replace the green o ring on the map sensor?
Nice one.Yeah
Nice one.
I've just ordered a big set of green ones as I measured it to be 6.8 x 2 (ish). Are both the black and green the same? Weird they'd fit 2 different coloured ones
Yeah I know, but both go into the same place! Strange they'd use a HNBR and then what I presume to be a normal NBR?There`s more to "O" rings than meets the eye.
https://www.marcorubber.com/o-ring-material-quick-reference.htm
There different sizes, the black one creates a seal and the green one prevents it being knocked out.Are both the black and green the same? Weird they'd fit 2 different coloured ones
