matched inlets
Car  Focius ST
dont know anything about mechanics really was just wondering would buying a set of second hand matched inlets be worth it or would i be better getting my own inlets matched?
cheers mike
As above. No difference.
The heads are CNC machined so if a set of inlets have been matched up to any 1*2 head they should match any other.
They will work with each other...
they go in this order of performance (the later being better)
172 ph1
172 ph2
182
CNC Matched inlets
The head inlets although the same appature are different again, the newer they are the more factory machining is done...........
just to throw into the mix, the ph1 heads make the best power.........
Andy
