I'd be happy if it was around the 220bhp mark tbh. A bit more than I'd get if I go with ITBs but more torque (I'd hope it was around the 195/200lb/ft mark).
Most importantly though its much, much cheaper. Especially if it'll run quite happily on the standard ECU which is something I need to check with Paul at RS Tuning.
If the standard ECU is capable (they can run a Rotrex so why not an Eaton) then I reckon I could do it for £1k all in. That's with Meg 225 injectors, intercooler, boost pipes, M45, material for making brackets and a remap. Whereas you're talking £2600 for ITBs, ECU and mapping and any other bits required.
Not sure how I'd have the charger. Draw through or blow through. If it's blow through then the standard inlet system can stay and just get a 2nd TB before the supercharger. Draw through then I'd probably get a new inlet manifold made up to incorporate the charger. Could even integrate a chargercooler system then as IIRC runner lengths don't affect Roots type chargers.
The downside is putting 20kg of weight back into the car in front of the wheels.
