Clio
Hi,
I'm looking for a trolley jack so that I can get under my car to bleed cooling system etc. The one I like says minimum saddle height, 145mm, maximum saddle height, 504mm. 50cm seems like a reasonable amount of space to work under, but then I noticed it also says 'maximum chassis height', 165mm.
Does this mean that I would only be able to lift my Clio by just over half a foot?
I'm fairly new to all this and have never been under a car before, but that seems like such a small space to fit under, especially when spending £80 on a jack.
Are all <£100s jacks like this - just 16cm actual lift or so? What is is that determines this 'maximum chassis height' - i.e. what would stop it from jacking all the way up to its 504mm max saddle height?
Thanks in advance. :approve:
