So my door now and again has had the issue that when i open from the inside and try to close the door it bounces back and doesn't lock into place and shut, to solve this all i did was lift the handle on the outside and close it and the door would then close fine.
Right now it has done it and none of it has worked, my door will not close no matter how many times i attempt to shut it, pull both handles and shut it. When i attempt closing the lock with a bar it hooks around and sticks but i can pull it back and it drops back down again. I try it on the working passenger door and it locks into place and stays in until the handle is lifted.
I'm unsure what to look at if i was to take off the door card, i'll happily replace whatever it possibly could be but right this minute i'm stuck with my door slightly open. Even if it closed just once i would be happy for now but i can't even do that.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
