Megs quickCLay advice please?
  Octavia VRS
it's easy mate. Wash the car first and then rinse it as you normally would. Make sure you are out direct sunlight and use lots of detailing spray as you need a good amount of lubrication when claying. Before you start rub the clay in your hands to get it softer, I did what Rich advised and put it in a bucket of warm water. Pull and twist the clay to reveal a new fresh side when it starts to become discoloured.
Think that's about it.
  106 GTi
The man knows! ^^^^^^^^
Split the bar into 3, saves using a whole bar to do a car if it does not need it. Also if you drop it on the floor it's not a whole bar down the drain. As Kenny said, keep kneeding it and folding it to keep it soft and always revel a a clean side to clay with.
On really cold days I wack it the m/wave first to warm it up proper.
The more QD or lube the better to avoid any danger of scratching, don't skimp on it, avoid doing it in hot sunlight.
  Skoda Fabia vRS
have some spare time afterwards aswell as you might leave the odd mark which will polish straight out
muz
  big fat japanese bus
and if you run out of detailer use water and a little bit of megs shampoo in the bottle ;)
