memory card help!!
Car  Fiesta ST
Hi,
Just got a g600 which, as its a samsung, wont connect to pc via usb (had same problem with d600 but that connected now and then) so I got myself a usb flash drive with built in SD card reader so I could atleast move stuff to and from the microSD card. When I put the flash drive in my pc i can access the built in memory and the microSD shows up but when I try to access it says I need to format it to use (works in the mobile). However when I try to format it it says unable to format.
Any ideas of what to do? I'm using Vista Ultimate 64-bit, the flash drive/reader is the Kingston Data Travel Reader and the microSD is a SanDisk 2GB.
Cheers.
