Memory Stick - HELP!!!
Maz
Car  LY 200
If a memory stick wont read in two different pc's does that mean its broken and I cant get the data off it in any other way :dapprove:
Spent the last two days doing an application form, saved on memory stick and now it wont work :mad:
what error message? if is not displaying at all, go to desktop > right click on computer > manage > look for it under disk management.
If your getting cyclic redundancy check messages its f**ked. I've had two do this.
it is not recognised at all by the computers?
give the connectors a wipe over.
^^ where are they ??
I have taken the cover off it and cant see that anything has blown.. is there no way a computer shop might be able to fix it/recover the data ??
Noting is happening at all :dapprove:
if you look under disk management is it listed? it may just need assigning a drive letter.
Its not under removable storage
It got really hot when it stopped working does that mean something has blown ??
it should list under disk management, i've not had them get hot before, could mean its bust.
take it to a computer shop. But its likely that it may have got to hot and maybe melted internal components of the memory stick.
As Gareth said, probably needs assigning a drive letter.
Go to Control Panel > Administrative tools > Computer Management > Disk Management, it should list it there in the bottom half of the window, right click - change drive letter and paths.
Should work, as a number of people at work cant access memory sticks for this reason.
Maz I hope your homemade p**n collection wasn't on there too! ;)
Sorry to hear about the application form, but doesn't sound good. Are you sure you havn't got it saved anywhere on your PC.
Nope no backup, worked in my laptop earlier today and then just didnt so its broken .. lol
Ah well not to worry ..
Recaro nope it wasnt as I dont have one
Jonas would be interesting to see what you have .. pmsl
If it was getting really hot its most likely one of the chips inside is fucked.... along the data that was on it 2
