When are these to be used? I assume they would clog up if you use them to take the wax off, so do you use them when you put the fine spray of clean water on to achieve a better shine?
I used mine to take the wax/polish off - gets rid of everything really well..
Also good for getting rid of water.. the quik detailer is good with them, cus they attract dirt and dont let it scratch your car with the rest of the wipe!
Can be used for drying you car instead of using a chamois. Also can be used for what you stated above, taking wax off and when put the fine spray on to wipe this off. They are generally machine or hand washable, so anything that clogs in them, can be taken care of. Generally when taking wax off with one of these cloths they do not get clogged, the dust will just fall off them. Hope this helps.
I think Ill take the wax off with a duster, then use it with the fine spray of water to make sure I dont get any fluffy bits. Not that it matters as by the time I get to DS itll be filthy again.
This is the first waxing mines ever had!!! And I can tell you now, itll never get a 3 stage unless I pay someone to do it. I really dont see the point as its dirty the very next day just driving to work.
