Milltek problem (197)
Car  Clio 197, BMW 330Ci
Anyone had problems with the milltek car back knocking against the boot floor and if so how did you adjust it away from it?
Had knocking since its been fitted and after having it on stands and diffuser off, the right tip is sat against the boot floors heat shield but there seems to be no adjustment in it to lower it down.
The tips also don't seem to be inline properly.
If helps I've got toyo mani, standard cat, milltek resonated cat back fitted.
Thanks in advance
