Minecraft FPS problem.......
  Not a 320d
So I recently upgraded my GPU to a 680.
I average about 500fps in Minecraft, but after playing for a minute or so, this will drop to about 7fps, then lower, then I must be on about 1 frame per 2 second interval. itll do this every time. Ive tried running in compatability mode, re installing the game, allsorts of things.
Temperature is fine.
I have 64bit Java.
Specs -
i5 750 4GHz, 8GB ram, GTX 680.
No other game has a problem. Just minecraft. Any ideas?
  Bus Winker
I have 64bit Java.
Specs -
Reinstall Java? If the fps are dropping after a few minutes I would suspect that its Java.
Btw, good use of the GTX 680 :p
  Not a 320d
I know right?! First game I played with it lol.
Was already getting 300fps on the 5870.
I have a feeling ti something to do with minecraft being 32 bit version. So ill try get 64 bit.
You tried increasing the amount of RAM Minecraft/Java is allowed access too? Can't remember how you do it but its in Java settings in your CP (Google will let you know). Mine drops FPS like a c**t when someone messages me on Steam and it's flashing. Crock of s**t.
  MK4 Anni & MK5 Edt30
Not just the server you're using is it? ie. Too much on it etc.
Tried running in SP ?
