I've had them on mine and for road use they are more than adequate, they do get some fade on track if you punish your brakes. The 1184 (think that's the number) are the ones to go for, better than DS2500's imo and I rate them extremely high
Ive just gone for standard renault replacements as there were so many mixed reviews on both ebc greens and extremes. So to play it safe ill just use stock items, which havent ever let me down. Might get some braided lines.
GSF sell Mintex Extremes, but when I asked they had to order them in.
EBC Greenstuff is what I got in the end on my Clio, much improved now and going off people said, they were a cheap replacement. As I had them once before and hated them, they fall apart and over heated on my old cars.
Well as said im just on normal roads, and im not that reckless as a driver, so these should be ample. If i was going on track then id get the pagid track pads which ive had before on my st185 more than ample
my brake need renewing so whats the best pad to go for and should i follow them with grooved and vented discs? what about greenstuffpads or are they to soft?
chrstian rea, it depends on what application they are being used for i guess. I went for something that was OE as it just worked and did what it needed. Ive read ALL day (im not joking) and there are so many mixed reviews on ALL the pads available. From squeeling to falling apart they all seem to be good and bad depending on what they have been used for.
Good luck with your decission, at the end of the day i think its personal preference.
