Hey guys. In need of a little help. Coming to completion on thw build of my clio but cant sort a rough idle and slight misfire. When revving from idle the revs drop before raising. Idle is quite lumpy too. Compression test shows all 4 cylinders between 195-200 after cylinder head rebuild and new valves. Cleaned injectors and tested resistance on injectors. All at 15 ohms. Had new spark plugs and leads. No codes coming in atm. Running lightweight billet flywheel, ac and pas delete and lightweight pulleys. Decat with o2 spacer. Anybody got any ideas?? Sorry for the long post
