Posted a once or maybe tiwce before about current problem so i wont rant on, list of whats been done;
New coil pack
New leads
New spark plugs
Previous owner kindly donated a 2nd hand fuel rail with injectors
After all this was fitted it ran fine, then developed low rev misfire (then fired on all 4 once under load) and now its back to feeling like the multiple misfire.
Today tried a quick test of disconnecting injector plugs and HT leads in turn to try to process of elimination but the became noticeable worse with each one i disconnected then smoothed out once plugged back in but still had the misfire.
Im still suspect of the injectors but the chances are unlikely that this second lot of injectors have the same problem.
Also done compression test 180psi on 3 then the last one been 100psi (but still in the green)
Obviously have the orange engine light which will either flash or stay on.
Point in the right direction would be great..i really miss my Clio!
New coil pack
New leads
New spark plugs
