Focus RS + S3
guys i need your help sorting a misfire,
Its a 2004 1.2 16v
I plugged it in and it was saying misfire, cylinder 4
No problem, so number 4 being (closest to engine mount) i pulled the HT lead off and no change,
I then plugged it in again and it now says cylinder 1 (nearest gearbox) but if i pull HT lead off there it splutters badly
Ive swapped the plugs between cylinders, ive swapped the injectors around and its still cylinder 1 showing on the cose reader
But its still no4 thats playing up.
I checked the coilpack
And someone has bodged the wrong one on previously, by filing and cutting it etc
So a correct one from renparts was fitted today and no change,
The engine management light flashes after 30 seconds of bad idling
Anything i can do?
Its a 2004 1.2 16v
Anything i can do?
