Misfire??
t90_lle
East of England
Under acceleration the car struggles and hesitates in low down revs in any gear, it's become worse over the last couple of days but is fine on idle. Didnt know if it would be the plugs, leads, or anything else???
Any help would be appreciated, much thanks.
Ollie
mine did this too. a few weeks ago..i used it daily and now today it does it in the all the revs but at times clears up.. and then does it again most of the time now..its best to take your plugs out and check them ..however my car has the dephaser puller rattle too which on mine i dont know if the pulley would cause that
Misfire can be, leads, coilpack, injector, plugs, lambda sensor.
Unplug the map sensor on the manifold. Run it and see if that's any good.
If you can plug it in do that. Otherwise it's best to let it get a bit worse until you see a light on the dash.
Injector will give a flashing EML when it gets quite bad. You could do the injector test
