MISSFIRE ON BANK 2&3
  Clio 172 cup
Not sure if anybody has come across the same issue
I’ve recently took my gearbox out after a failure at brands hatch , upon reinstalling it the car has now developed a misfire
Only on bank 2/3
I’ve replaced plugs , coil & leads
I have power to the injector plugs but when I unplug injector 2/3 when the cars running it makes no difference at all
I can also u plug coil 2/3 whilst the cars running and still no change
Have also tried another set of injectors and the same thing happens
I’ve continuity tested / load tested the cables from the coil pack back to ecu pins and there all fine
