Clio 172
				my clio 172 started misfiring on one of the cylinders on monday evening. I went for a short drive to tescos and it was fine . when i came out to drive off the problem started.
Since then I have changed the leads , coil pack, checked each spark plug. they all seem to fire when they are not in the engine.
I managed to get it to fire on 4 cylinders for about 5 mins when i used some damp start before i started buying parts. This is what made me think it was the HT leads playing up. But as i was driving to see how much new HT leads where it just started misfiring again. Seems to be worse under load conditions, or at least that what seemed to set it off again.
I have ordered some new NGK plugs for tomorrow hopefully this will make a difference. But I dont have much hope as I have seen all 4 current plugs create a spark when not inside the cylinder. so there is voltage coming from the coil through the HT lead to the plug.
This is what made me then think it could be the coil pack, if there was a spark but maybe the voltage was to low for it to be a strong spark. But no difference with new coil pack.
Any ideas will be appreciated?
