Mitt & Microfibre Care
  Golf GT & A4 Avant
once ive finished washing the car i run the hose or pressure over it to clean it up, ring out as much water as possi le then leave over the edge of my bucket typically
leave it somewhere it can air and not freeze
Sheilas’ Wheels
  Whichever has fuel
My wash mitt gets run under a hot tap until all the soap is out and then left on the side in the kitchen until its bone dry. Then gets putin the bucket in the shed.
If you leave them damp in the garage they start to smell musty and I can't stomach that smell, hence my need to keep it bone dry! lol.
As Dan says. If you leave them damp you run the risk of odours and (a bit like leaving a dish to soak) the fibers may fall out as the glue softens.
aucky
Run water through it and make sure theres nothing trapped in the fibres.
Shake it outside to throw most fo the water off.
Leave in a warm-ish place to air out (E.g. airing cupboard)
Run a comb/brush through it when its slightly damp to prevent it matting.
Flat Eric
Sing Hosanna!!
  F31 35d, Berlingo Na
Like the sound of brushing. ;) ill try that one next time.
aucky
Yeah, it will malt a bit but it returns it closer to the original condition instead of how it was when it was still on the sheep.
  5 GTT & Orb'd Trophy
Leave my lambswool mitts to soak in a basin or bowl and the fibres seem to separate and release any trapped particles, Micro fibres get washed in the washing machine with woolite. Do not tumble dry.
  Clio 182, Astra Sri
as said already, rinse thoroughly then hang up to dry.
as for washing your microfibres, i put all mine in the washing machine with a cap full of aldi's 'almat' non bio gel. its cheap, and cleans better than any dedeicated MF wash products ive used. a drop of distilled vinegar in the rinse compartment will help remove any wax residues on them too. i do this for any foam pads aswell.
machine pads get a pre soak in fairy liquid then chucked in the washing machine as above
Best way to look after the Auto Finesse Mitts is hand wash with warm water not hot.
With Micro fibres cloths and towels these can be machine washed 40 degrees with a non bio detergent (do not use powder or fabric softener)
Sian :)
Tumbledrying is bad mmmkay?
IMG-20120529-01111 by Adam, on Flickr
497adam
  clio 172 phase 2
I hand washed mine recently with nikwax tech wash (for goretex act) seem to work well
497adam
  clio 172 phase 2
Because its just a very mild non bio liquid detergent, it doesn't add any water repellency
497adam
  clio 172 phase 2
A non-detergent, biodegradable liquid soap which removes dirt and detergent residues,
497adam
  clio 172 phase 2
No just designed to clean them without damaging ( they do a specific re proofer a bit like unibond) which is why I tried it. Worked well
